This topic may have been covered elsewhere, but I am wondering what the running clearance should be between the rear axle diameter and the bronze bush bearings.
I am building a 4″ Little Samson which has an axle diameter of 1.375″. The bearing material I plan to use is Hidurel 5, also known as Colisbro. There are two bearings at opposite ends of the cast iron axle tube. I have read of using 1 thou per inch of diameter, but when I discussed this a while ago on the LS forum, it was suggested that this was not enough because of the temperature rise.
Any guidance on what clearance I should machine to would be much appreciated.
John R
