Bantam VS speed control
Home Forums Electronics in the Workshop Bantam VS speed control
  • #764302
    Norm
      @norm
      I have a Bantam VS on which the speed readout sometimes works sometimes just show zeros. The rheostat has no effect. It has been suggested that the capacitor have probably gone down on the PCB.
      Can anybody help or suggest somebody to repair it?
      bernard towers
        @bernardtowers37738
        Can a moderator put the spelling mistake right as it might get overlooked by a potential helper.
        #764350
          Done.
          As to Norm’s problem, intermittent operation is often due to a loose connection, so check them and the wiring.  Also make sure the sensor on the spindle is clean and correctly aligned.
          Norm
            @norm
            Thanks Dave, have done both your suggestions. I think it’s on the PC board somewhere. The trouble is my electronic knowledge is very limited.
            Thanks anyway.
            #764709
            Circlip
              @circlip
              Check the PCB (PWB to be technically correct) for dry joints, some joints on  modern electroniks crack due to the stupidity of ‘those that know’ to  eliminate Lead in solders, and we won’t even start on non Cadmium Silver Solders!
              Regards  Ian
