Hi Derek,
The question of two or three cylinders is nothing to do with being "modern" (or not). The later Flying Scotsman design (published in ME) offered a choice of building in 2 or 3 cylinder versions – the 2 cylinder version being simpler and easier to build. Most G3 locomotives are two cylinder in fact, although there are some very nice 3 cylinder engines around (and indeed single cylinder ones too – although not Scotsmen that I recall)
However, I think you should consider making your model a battery electric one – it would be a lot less expensive than a live steam version but would not preclude later conversion to steam when funds or ability permit. This has been done before in fact (by several G3 Members) and for pretty similar reasons. I know of one engine that was converted probably more than 30 years ago now (as a "short term measure" ) that is still happily running in its electric form. You could buy a commercial motor/gearbox or build one yourself – not impossible even with hand tools (because that has also been done before).
BTW – I've read the previous comments on support for 2.5" track (or lack of it) at some MES and without wanting to get into a bun fight – I think that we are into the same (old) discussion about 'passenger hauling' versus 'scenic' again. I perfectly understand that someone who wants to build a passenger hauling engine might choose a larger gauge. Quite apart from the satisfaction of building in the larger gauge, it's not surprising that a larger engine can generally pull more load e.g. passengers. Given that many MES operate expensive grounds and facilities (and earn essential income on Public running days) it's very easy to see why larger engines/gauges are attractive to MES members.
So does size matter? Of course it does if you want to pull children around your local MES track. I used to build in a larger gauge and belonged to a local MES but I discovered that my interests generally lay elsewhere. Size (be it gauge or scale) is also a matter of perspective to some extent. To most MES members, 2.5" is too small to be "useful" – whilst to many Railway Modellers, G3 is too large to accommodate. To me, it's just the right size to build interesting locomotives and stock that is affordable, allows the level of detail I need and that suits my abilities (e.g. eyesight) and machinery.
What does this mean in practice? Well, I currently own five 2.5" live steam engines in various stages of build (from complete to just started – more if I count the couple without boilers) – plus three battery electric engines (again one complete and two "in hand" ). My enjoyment comes primarily from the actual building and design of these engines (I haven't fully designed a live steam engine yet but all the battery electric engines are to my own drawings). Whilst I obviously go to G3 GTGs, it's mainly a social thing for me – to meet old friends and see (& admire) their work. Most of my hobby is in fact, a somewhat solitary one, as 99% of my "G3 time" is spent in the workshop.
Why is this relevant? From what I've read of this thread (and seen from your photos) you seem to enjoy "making" things and (especially given your limited resources) you seem to have made great progress too. Whilst some here might have very useful expertise for you, it might also be that their interests and enjoyment come from entirely different areas to your own. So my advice is very simple, try to get clear picture in your own mind what you want to get/achieve from this activity, then set yourself reasonable/affordable goals (something I'm not good at by the way) and just go for it. There is little point in worrying about cylinder connections if you cannot afford a boiler. But it would only be a small step up from making a good "display" model to making a really nice (battery-electric) working one.
IanT
Edited By IanT on 14/08/2016 09:31:39
