I have never used, or felt the need for, smart charger, relying instead on a bog-standard home built device constructed something like 50+ years ago. It consists of a 240v transformer with two outputs, one for 6v & the other for 12V feeding into a selenium full wave bridge rectifier via a rather large rheostat and a moving iron ammeter.
I also built the batterty monitoring device published in ME some 20 years ago, could it be by Gordon Read? This maintains the battery voltage between two set limits, and cycles the battery as well, this under control of a relay. Unfortunately, during the winter of 1995 (I think), the temperature around here dropped rather dramatically (the hydraulic fluid in the lifeboat stationed 7 miles away turned to slush and ruined the engines!), and the relay froze in the discharge position. The battery was sat on a concrete floor, adjacent to a door, and as far as I can tell, one end cell must have frozen. That was the only battery that I have ever ruined in 50+ years of using them.
I have had problems with so-called leisure batteries for my caravan. There used to be, and maybe for all I know still are, cheap batteries available for around £30 supposedly suitable for caravans and described as 75Amp batteries. Unfortunately, their capacity was somwhere in the region of 30hours at the usuall 20 hour rate. On buying an Exide leisure battery, firstly I very nearly dropped it due to it's weight, secondly at was rated at 75Ah, note the extra letter, at the 20 hour rate, and easily exceeded that rating on test. Today, if I need a new leisure battery, I look for a recognised make, Exide being my favourite, and secondly, ensure that the rating is for at least 75Ah at the 20 hour rate. I then don't have any problems other than self-inflicted ones. If anyone describes them as a 75Amp battery, I always go elsewhere.
It should be noted that leisure batteries are designed for deep discharge, whereas, as has been said, starter batteries as fitted to vehicles, are designed for very heavy, short term discharges, followed by moderately high re-charging. Here again, I have been caught with cheapish batteries with a, say, 3 year warranty, and lasting on the car, a month or two over the 3 years, whereas, a Bosch 4 year warranty was still working, albeit on its last legs at 6 years old. My present car, a Toyota Avensis 1,8 petrol, had to have it's battery replaced at just over the 3 years: it now has a Bosch 5 year warranty battery which is almost 3 1/2 years old.
Finally, may I comment on telephone exchange batteries, the ones that were used with old-fashioned Strowger exchanges. In many instances these were many years old, possibly into the 20's. Very early on these were used in pairs on a 24 hour charge-discharge system, later they were used either singly or in parallel on a partial charge/discharge where as the battery became discharged, the rectifier would automatically switch on and supply some of the daytime load except through the night when the load dropped and all the charging current went into the battery, and later still, on a parallel float system where the main load was taken by automatically controlled mains driven rectifier units.
Peter G. Shaw
