Going back to my Dome Barograph to further investigate the ‘stiction’ as I called it. I have found the cause to be the two sleeve bearings supporting the pen shaft. When air pressure changes direction the pen indicates the true reading for a small change but then lags behind. The sleeve bearings have some looseness so that at a change of rotation the pivoting is rather like a knife edge bearing for a degree or two. Then the pen shaft begins to climb up the side of the outer part of the sleeve so causing a lag in response to the pressure change.
I have replaced these sleeve bearings with miniature instrument ball bearings ensuring that the mechanical change can be reversed if necessary. The improvement in performance has been remarkable, going from a mere indication of the atmospheric pressure changes to something that truly follows the actual readings at my local airfield.
To say the least, the barograph has been transformed and this has happened following my digesting of the previous postings and a bit of lateral thinking. So many thanks to all who offered their suggestions.
