Bandsaw – wood and metal ?
Home Forums Beginners questions Bandsaw – wood and metal ?
Viewing 2 posts - 26 through 27 (of 27 total)
  • #540304
    not done it yet
      @notdoneityet
      Hi Gerry,
      Your first posting indicated the use of a vertical blade – so did you buy the table kit, to be able to convert it for vertical operation?
      At 3 or 4 times as much as the aldi/lidl offering I expect it is likely to last a lifetime of hobby use.
      Tuffsaws indicate that their blades can last longer than those advertised on stakesys. They are likely a little cheaper, too (mine were) – especially if buying multiples as differing tooth counts.
      I’ve no experience of blade life comparisons yet, but Tuffsaws do get good reviews, particularly from forum members.
      Howard Lewis
        @howardlewis46836
        Hi Gerry,
        It sounds as if you have just about licked the machine into shape for metal cutting.
        A 14 tpi blade will cut timber, but a coarser one would be better for that, to reduce then risk of clogging.
