What worked on my generic 4.5″ bandsaw was to tension the blade, after all the other adjustments, ALL Guide Rollers, before finally adjusting the tracking.
(I had made a tension meter to the Jacques Maurel design. Time well spent)
Once set up, a probably never to be repeated test result, was an unbelieveable difference in thickness of a thin slice of steel of only 0.001″
It might be that the thick wood heated the blade to point where it partially stress relieved, and slightly distorted, leading to the reluctance to stay in place.
It is taken as read that the pulleys are not a loose fit on their spindles.
HTH
