Hello Robin,
Thank you for completing the story with a successful result. So often the final outcome remains undisclosed.
I still support the cardboard 'cushion' as a means of quietening the cutting, some materials are inherently noisy emitting an ear splitting shriek as they are being cut.
The ideal is for at least two but as long as one tooth on the bandsaw blade remains engaged in the cut as the second is entering, you will get a smooth cutting action. The trouble starts when the section being cut is thinner than the tooth pitch spacing on the blade and each tooth has to cut it's own track. It gets noisy and rough and can damage the blade.
A dodge for those situations is to exploit the angled tilt facility if your bandsaw can support that ability so that the material being cut is presented to the blade at a ramp angle that lengthens the cutting path and once again keeps at least one blade tooth engaged before a second enters the cut. Not all machines offer this added refinement
Edit addition. The other trick frequently used is to make a sandwich and cut the two materials at the same time
Regards Brian
Edited By Brian Wood on 20/08/2020 09:47:17
