Ball Nose Mill Cutter, did I break it?
Home Forums Beginners questions Ball Nose Mill Cutter, did I break it?
  • #5043
    Aidan Browne
      @aidanbrowne70238
      Aidan Browne
        @aidanbrowne70238
        Hi,
        I have just started making a Stuart D10 stationary engine and I needed to make a 7/16 inch semi-circle on the bed of the engine for the crank carriers to sit on. My plan was to use a 7/16 inch ball nose cutter to do this.
        I order one on Ebay with the description
        7/16 INCH. BALLNOSE SLOTDRILL 2 FLUTE  HSS GRD  MADE IN ENGLAND      PLAIN SHANK
         INDUSTRIAL STANDARD…
        it arrived and I set up the engine bed on the mill and gently plunged the cutter into the casting. It didn’t sound like it was cutting well and removed it immediately only to see that the flutes had been worn away and the tool was overheated. It’s only cast it’s going into and none of my other cutters have had a problem. Did i get a dud or did I do something wrong.
        #50983
        David Clark 13
          @davidclark13
          Hi There
          Try a file on the cutter.
          Then try a file on the cast iron.
          The cutter should cut fine on cast iron.
          I used a modified slot drill converted to a ball nose and had no trouble.
          I did not go straight in to full depth but after aligning the cutter with the centre, went down 30 thou at a time. This is not because the cutter would not take that sort of cut but rather because the cutter would probably deflect.
          Go down to aproximate depth and then widen slot a couple of thou at a time until bearing fits.
          Finally ensure cutter is at full depth.
          I went about 5 thou wider and deeper than required to allow for paint.
          I cleaned up the sides and underside of the bearings before milling the slot.
          I think I described this in Model Engineer a while back.
          regards David
          #50984
            Its possible your casting is “chilled” this happens when the casting is cooled to quickly and results in very hard metal. Try giving the area a couple of strokes with an old file, if that does not touch it come back and we can suggest a few options.
            I have heard that quite a few of Stuarts castings are comming out chilled lately.
            Jason
            #50985
            mgj
              @mgj
              What revs were you using.
              At 500 rpm or so it should have walked through it. Cutting to D/2, with a reasonable mill and a proper milling chuck you could have taken that out in two passes plus a finishing cut.
              Jason – you beat me to it. I hadn’t heard of recent casting problems but they are fairly thin sections so that’s a possibility, but he ought to have been OK. He might have bluntened it, but not knackered it, which is what seems to have happened.The file test is OK in so far as it goes, on a virgin casting, but you still have to get through the skin.
              Still it doesn’t sound as if the cutter is too grand.
              Not often you find bargains with milling cutters, and the ones worth having tend to be expensive. Sorry, just one of those things.
              (One of the reasons, said he having a dig generally, why I built a Quorn. In terms of resharpened milling cutters and the ability to operate without fear at reasonable cost at industrial feeds makes it well worth the effort)
              Edited By mgj on 21/04/2010 17:56:24
              #50993
              Aidan Browne
                @aidanbrowne70238
                Thanks for the quick responses. I have milled the other side of the same casting flat with an end mill and it went through it like butter so I think the castings are OK. All the other castings I have worked in the kit have been OK also.
                I was running the Ball nose slot drill at 600rpm approx. I think it’s beyond a file it just deteriorated in a second and barely marked the casting. The flutes at either side have lost their correct width now, so I think they are useless.The edge on it was very sharp but obviously very soft. I don’t know if this matters but there is an initial semi-circle in the casting and I’m just trying to enlarge it to the correct size.
                I had trouble finding a ball nose drill  from any of the online shops. I have bought a lot of the stuff I needed from Chronos and they have been excellent but they do not have a Ball Nose slot Drill in the size I need.
                As I said earlier I am very new to model making and could be going about this in completely the wrong way. I’m really enjoying it at the moment and it’s very addictive. If there is a better way for me to carry out the job I need to do, I would be glad of your advice.
                #50996
                mgj
                  @mgj
                  600 is a bit swift.500 is probably about as fast as you ought to go in a fairly rigid machine.
                  Sounds like a poor cutter.
                  Turn the casting through 90 deg and mill your half circle with the side of an endmill. Its not “better” it just saves having to buy a new cutter.
                  #51016
                  Chris B
                    @chrisb73862
                    When I did the bed for my 10H, I didn’t bother with a ball nosed cutter, I just used a round file to give enough depth to let the bearings sit down and then tidied up the sides with a slot drill to give a snug fit to locate the bearings.
                    CB…
                    #51026
                    DMB
                      @dmb
                      Hi Aidan,
                      Try using a carbide cutter, which will not be blunted by chilled iron like HSS. Or use a small rotary grindstone as supplied with the hand held rotary tools.
                      If you can, get a proper Clarksons milling chuck and screwed shank cutters to fit. Trust me, their the “bees knees.”!
                      Circlip
                        @circlip
                        Awww don’t tell them about Clarksons Mr Coleman, you’re ruining the market for us oldies.
                          Regards  Ian.
                        #51178
                        Aidan Browne
                          @aidanbrowne70238
                          Hi lads,
                          I’ll try the file and slot drill method and let you know how I got on. I have a Clarkson milling chuck that came with the mill it’s an Int 30 but I only had the 4 basic collets. I found it really good but I have started using the ER collets lately as they are so handy to change.
                          I’ll let you know how I get on, and thanks for the advice.
                          #51199
                          Sub Mandrel
                            @submandrel
                            FWIW I used a round file when I built my 10V…
                            elanman
                              @elanman
                              Hi,
                              I built a Stuart H10 a couple of years ago and found most of the castings had a very hard skin, the thinner parts being hard right through. I had to use TCT tools to machine most parts. I was not impressed!
                              Cheers
                              KWIL
                                @kwil
                                John,  Clarksons have only have 4 “basic” collets per imperial and 4 collets for metric unless you get a larger Clarkson. I would not use an ER on a milling cutter as they can pull out under use. The Clarkson principle stops all of that.
                                #51234
                                Versaboss
                                  @versaboss
                                  Hmm, KWIL, what do you think the ER system was invented for? These collets are used on umpteen thousands of professional machines. In theory you may be right, but in practice that never happens, when the collet nut is closed correctly and the cutter sits completely in the collet.
                                  The danger of the pull-out is much higher in the ‘one-sided’ collets like the W-types or the C-types from the U.S.
                                  Greetings, Hansrudolf
                                  #51241
                                  KWIL
                                    @kwil
                                    Hansrudolf, I am aware of the ER attributes and that it was invented in CH by rego-fix, but we all cannot afford such expensive precision items.
                                    #51244
                                    Circlip
                                      @circlip
                                      Leave it Kwil, more for thee an me
                                        Regards  Ian.
