Hi Joe,
I’m presently working on an 0-6-2 tank loco based on Simplex castings and my intention is to fit balanced slide valves to reduce the load on the valve gear.
The principle behind balancing the valve is to isolate part of the upper surface of the valve from the steam pressure in the steam chest so reducing the force pressing the valve onto the port face. If you do a search for balanced slide valve on the net you’ll find some info which may be useful.
There are various ways by which this can be done in ‘our’ sizes but will probably require the valve design altering and also changing the drive from the slot and nut to a buckle type drive on the outside of the valve.
One simple way is to turn a short spigot on top of the valve which holds an O ring between the top of the valve and the underside of the steam chest cover. This seals the area inside the O ring from the steam chest pressure. I am not sure how long the O ring will last used like this as they are not really designed to slide. The underside of the steam chest cover would need to have a very smooth finish. This method has been used though and described in Model Engineer a couple of times.
Another way is to fit a ‘balance’ piston into a bore in the top of the valve which presses and seals against the steam chest cover, again isolating the part of the valve containing the piston. Another version of this has the balance piston mounted in the steam chest cover and the piston has a flat plate that presses on the top of the valve. If you have already made the valve, this option might be possible as the plate could press on the four corners of the valve left after machining the slots for the drive nut and the valve spindle?
Both of the above methods need a small ‘vent’ hole so that any steam that does get past the O ring or balance piston is vented to atmosphere or exhaust otherwise the pressure will build up on the top of the valve and render the balancing ineffective.
I’ve done a bit of research through articles in Model Engineer etc. and it seems to be the practice to make the area of the balance piston (or O ring) about 0.9 times the area of the exhaust cavity in the valve.
I’m just designing my set up at the moment but haven’t finalised my ideas yet so I can’t say for definite how I will do mine. However, I do intend to have the exhaust exiting through the top of the valve and a balance piston and then through the top of the steam chest cover. (This is the method Don Young used for his 5″ gauge Hunslet). This gives a freer exhaust as the steam does not have to exit via the usual tortuous route through the exhaust port in the port face. If you like, I’ll post some more details when I’ve finally sorted the design.
