Posted by Adrian R2 on 10/07/2023 09:45:01:
@Andrew, I haven't spent any money so far but yes it would be nice to have better kit but that probably means a big chunk of 3 phase iron and an inverter to run it. All the reviews I found of replacement wheels had someone complaining theirs was out of balance from new.
@Noel, indeed. The bearing I chose has a contact area on the wheel which is very close to that of the dished washer so stresses are I think OK, if it needs a bigger bearing then a spacer could be made to suit. That said I did turn it on using an extension lead from across the room rather than standing right next to it.
My £25 B&Q 6" bench grinder is fine with no vibration even when I remounted the stones.
You need to buy your budget grinder from somewhere local so you can take it back when it behaves like your does.
It simple to check wheel wobble with a pencil and an out of balance (weight) wheel will always stop at the same point.
Now I'm not one to stop innovation, but I wouldn't want to fudge a grinder with bent axles or a stone that runs true, but still produces a wobble, the wheels are not reinforced like angle grinder ones so continuing to run one might eventually break even an otherwise good wheel. Not forgetting that by then you will be stood in front of it.
