bakerlite substitute
Home Forums Materials bakerlite substitute
  • #131848
    clogs
      @clogs
      Good evening,
      anyone know of a substitute material very similar to Bakerlite…..
      I need to fabricate a few items, Horn buttons switch knobs etc for an old car…
      Nylon just doesn't look or feel right……would prefer muddy black in color but
      "Beggers can't be choosers"
      many thanks Frank
      clogs
        @clogs
        #131854
        Sub Mandrel
          @submandrel
          Try tufnol rod.
          Keith Long
            @keithlong89920
            You beat me to it Neil.
            Tufnol is the same type of plastic material but with different fillers to the original bakelite. I've just bought plastic rod/bar via the following website – http://www.directplasticsonline.co.uk – and was very pleased with the price and delivery – no other connection. Might be worth giving them a ring and see what they can offer. Otherwise it could well be a case of doing the rounds of charity shops and local auctions to see what comes up that can be recycled into what you want. There were a lot of ornaments and small household items made in the original material that will have suffered the ravages of time and won't be worth restoring, but a new life as a switch knob etc might be possible.
            Keith
            Edited By Keith Long on 06/10/2013 19:19:47
            #131861
              Frank,
              Despite my enthusiam for Tufnol. I think your best bet is probably something like Corian, as used for up-market kitchen worktops. The wood-turning suppliers sell blanks for making pens and cutlery handles.
                Yes Corian is easy enough to turn and mill, I use it for insulators on IC engine ignitions when I'm not using it in kitchens and bathrooms. They do a colour called "Coffee bean" which would be about right for a muddy black. You may strike lucky sending for a sample which usually come as 50×50 squares of the usual 12mm thick material.
                Edited By JasonB on 06/10/2013 19:52:09
                #131864
                speelwerk
                  @speelwerk
                  To imitate Bakelite (named after its Belgium inventor Leo Baekeland), you can use a epoxy resin and add carbon powder to the mix. You have to experiment a little with the amount of carbon to get the right gritty feel, or add a second corser filler to get it more gritty. Niko.
                  #131981
                  clogs
                    @clogs
                    Hey thanks. the collective knowlege u guy's have is better than Google, I'm amazed…
                    many thanks Frank
                    #131984
                    JohnF
                      @johnf59703
                      Hi Frank assuming the components are black in colour I wouls suggest Ebonite which is a hard black material, it can be turned, milled etc and can be polished to look like the knobs etc in old vehicles. Its used extensively in the gun trade for stock work. If you need a supply PM me and I'll see if I can help.
                      daveb
                        @daveb17630
                        Architectural salvage, old door knobs.
                        John Shepherd
                          @johnshepherd38883
                          Frank
                          Have a look on vintage wireless web sites, they often discus repairs to Bakelite. **LINK** is an example. It may add to the good advice you have had so far.
                          #136872
                          MICHAEL WILLIAMS
                            @michaelwilliams41215
                            (1) There are cold casting resins available which simulate Bakelite very well – even down to the mottled and swirling surfaces if you want .
                            (2) Bakelite is a very simple plastic . With a metal mould and a simple heating and compacting device you sould be able to make actual Bakelite components .
                            MikeW
                            #136891
                            daveb
                              @daveb17630
                              MikeW
                              Mike, I made some Bakelite many years ago, had a problem with the items cracking when they cooled (possibly needs to be cooled slowly) Some of us could probably use this stuff, is there any info available on making and casting it?
                              Scott
                                @scott
                                Doesn't Bakelite contain asbestos? Possibly not a great idea to "recycle" old Bakelite into something else if it involves machining?
                                #136900
                                  Posted by Scott on 02/12/2013 21:31:01:
                                  Scott,
                                  That's a good point …
                                  Bakelite, itself, does not contain Asbestos; but some of the manufactured products do.
                                  These will, predominantly, be the more "technical" ones … but Asbestos was used as a pretty general-purpose filler; so who knows where you might find it?
                                  Edited By Michael Gilligan on 02/12/2013 21:57:46
                                  #136903
                                  Oompa Lumpa
                                    @oompalumpa34302
                                    Where do people get this crap from? Have you actually taken the trouble to look at the composition of Bakelite before you posted this?
                                    No, Because if you had you would know it does NOT contain asbestos.
                                    Let's suppose it DID contain asbestos, what TYPE of asbestos would be the next question!
                                    (But it can contain Linen so maybe we should start looking for the missing bit of the Turin shroud in old Bakelite?)
                                    You CAN add various compounds to make it more suitable for the application.
                                    My Asbestos Roofed garage (we have to consider gravity here of course) has been recycled into my workshop. Are you suggesting that I stand outside to work?
                                    Or shall I just chance it?
                                    graham.
                                    #136909
                                    Jeff Dayman
                                      @jeffdayman43397
                                      Just FYI, the Bakelite company is still in business as Sumitomo Bakelite North America. There are also divisions of the company in the far east. Link to NA company is below. They offer many phenolic resin compositions for various jobs.Finding the exact grade and colour of phenolic resin today to replicate car parts from many years ago may be difficult but if any company can help it is probably Sumitomo Bakelite North America or their Durez division.
                                      They may be able to supply small quantities of new phenolic resin for experiments. However, with the exception of some specific electrical applications and some specialized brake components for cars, phenolic resins have largely been replaced in industry by engineering thermoplastics and epoxies. Many thermoplastics have superior strength and ductility, superior electrical properties, and similar high temperature resistance to phenolics but are MUCH easier, cheaper and faster to manufacture. Your neighbours may not like you moulding phenolic thermoset resin in your home workshop either – it can be smoky and VERY unpleasant smelling. I have worked with plastics for many years in industry and one firm I worked for had 8 presses making thermoset electrical parts from various Durez phenolic resins for a few years after I started there in the mid 1980's. Shortly thereafter the firm redesigned these parts in DuPont's Rynite polyester / modPET thermoplastic resin at great savings in resin cost and processing cost. Mechanical properties were also improved greatly. Physical appearance of brown and black Rynite is very close to brown and black phenolics. Some thermoplastics are just as smelly as thermoset phenolics during moulding but many are not, and mould easily if recommended temps and other settings are followed.
                                      JD
                                      #136931
                                      Springbok
                                        @springbok
                                        Frank
                                        I was sadly buying up some of the contents of an engineering firm in Cheltenham and the chap kept throwing into the back loads of black plastic saying you can have this lot free. mainly Akulon PTFE PP6 Din 16980. loads of black.
                                        Now the next big Q is have you got a lathe and able to do ball turning, correct taps if it an old car think baybee BSW or BSP. if not send me a drawing, as I am in now my 70's will need to sneak into what was my/business/ workshop when my lads are gone.
                                        Bob
                                        #136942
                                          Posted by Oompa Lumpa on 02/12/2013 22:33:59:
                                          <etc>
                                          Graham,
                                          I suggest that you read this.
                                          Scott
                                            @scott
                                            Apologies for my loose usage of the term "Bakelite". I, like many people, have a habit of using the term in a general sense to describe products containing Bakelite, products which may also contain other filler materials such as linen and asbestos. I know this from the decommissioning of old MoD assets where samples were sent to a lab for analysis and some seemingly innocuous items such as telephone handsets were found to contain asbestos. You are correct in your assertion that Bakelite itself does not contain asbestos. You obviously also know that it is often mixed with other things.
                                            As for your garage/workshop roof, I'm sure you are just as aware as I am that asbestos is not hazardous unless it is disturbed so it's not relevant in the context of my initial offering which was merely intended to flag up to the OP that old products containing Bakelite may present a risk of asbestos exposure (in case he was not already aware) if machined. Since the "recycling" of old asbestos products into something different had been suggested by others I do not think that unreasonable although you clearly do.
                                            Ultimately people have their own idea of what is a safety concern and what is "crap". Not my place to tell anyone how conduct themselves in their own workshop but I assume people wish to make balanced, informed decisions after researching an issue to a level that they deem acceptable. Each to their own!
                                            Scott
                                            #136951
                                            Oompa Lumpa
                                              @oompalumpa34302
                                              Scott, please accept my apologies for being rather abrupt.
                                              For lots of reasons that I am not going to go into publicly Asbestosis and Silicosis are two diseases I have knowledge about.
                                              I am only a recent member of this forum but I really, really like it here. It is, by and large, a very friendly place and populated by some very knowledgeable people willing to share that knowledge freely. I really do not wish to achieve the status of "Keyboard Warrior", I will leave that to the Trolls.
                                              The issue I have (and I hope this is received in the spirit it is meant) is the blurting out of random statements with no foundation. There are a great many gulliable people out there and "it MUST be true, I read it on the Internet" is an all too familiar phrase. It does nobody any good. I know, I am not the keeper of the Internet but one thing happened from my outburst and that is we have some real facts now posted. So if nothing else, some good came of it
                                              graham.
                                              #136953
                                              jason udall
                                                @jasonudall57142
                                                Guys..The asbestos thing is well taken. ..
                                                From the vintage of some original bakelite parts asbestos might have been used.
                                                One should also note the old machine tool s might have been painted in lead based paints…use asbestos in friction linings and leaded solder in the wiring.
                                                The current generation might not have met these materials and be completely taken aback and worse still have no expectation of the presence of such.
                                                That said there would be a difference in occasional exposure and occupational exposure
                                                #136955
                                                Springbok
                                                  @springbok
                                                  Well Oompa Loompa and as we we say in Glasgow stick it up your jumper. thought you were a bit harsh,this forum is for helping people not critical path analysis. so Frank if you want to tke my offer it the only cost to you will be postage
                                                  regards
                                                  bob
                                                  #136956
                                                  Scott
                                                    @scott
                                                    No worries Graham. As you say it's a good forum and the main thing is that we all learn from it
                                                    Scott
                                                    #136957
                                                    Oompa Lumpa
                                                      @oompalumpa34302
                                                      You are quite right Jason, the current generation have very limited experience of some of the dangers many of us were exposed to.
                                                      The lead based paint thing is also something I have a bit of experience (!). The many people I saw back in the early nineties burning paint off in Victorian houses…… No warnings in any of the DIY emporiums. The people din't really concern me, but many were young families with children, renovating these houses after work and by inference after school.
                                                      As you say, little experience and some of the things I and I am sure many of the people here did during our apprenticeships under the instruction of our Master would probably get them a lengthy jail term today!
                                                      graham.
                                                      (and up yours Bob if you want to play tit for Tat)
                                                    Home Forums Materials Topics
