Inspired by Andew’s and mgj’s postings I did my own trials. Where possible I used identical conditions to those used by Andrew for a comparison. So, excuse my plagiarism and herewith the result. Photos (not very good) are in my Badger’s Bum album.
Lathe: Colchester Student 1800, running from an inverter supply.
Workholding: Burnerd Multi-size collet chuck
Material: 1.375″ diameter steel – horrible old gas or water pipe, probably galvanised.
Depth of Cut: 40 thou, ie, 80 thou off the diameter.
Feed: 4 thou per rev.
Coolant: Rocol Multisol, 20:1 Dilution
Tool Tips: I used two different inserts and M42 HSS tangential tool.
The inserts were:
Korloy |
CCMT09 |
Grade NC3120 |
0.2 mm tip radius |
Sumitomo |
CCGT09 |
Grade T1200A |
0.2 mm tip radius |
The tangential tool is the Oz version from Eccentric Engineering. I gave it a quick sharpen and a slight radius.
The Sumitomo inserts are the Titanium Carbide grade that is claimed to be effective at much lower surface speeds than nor
The Sumitomo inserts are the Titanium Carbide grade that is claimed to be effective at much lower surface speeds than normal Tungsten Carbide.
The trials were:
1: Korloy, 230 rpm (83 sfm) with flood coolant
2: Korloy, 230 rpm (83 sfm), dry
3: Korloy, 1800 rpm (648 sfm) with flood coolant
4: Korloy, 1800 rpm (648 sfm), dry
5: Sumitomo, 305 rpm (110 sfm) with flood coolant
6: Sumitomo, 305 rpm (110 sfm), dry
7: Sumitomo, 1800 rpm (648 sfm) with flood coolant
8: Sumitomo, 1800 rpm (648 sfm), dry
9: M42 HSS, 230 rpm (83 sfm) with flood coolant
10: M42 HSS, 230 rpm (83 sfm), dry
As the results with this were – err badger’s bum – I tried progressively reducing the depth of cut from 40 to 20 then 10 thou.
11: M42 HSS, 94 rpm (34 sfm), dry
The results were
Trial 1 |
Korloy |
230 |
rpm |
Coolant |
28 May 2011 at 20:58
#69285
Participant @hughgilhespie56163
More 2
The results were
