Shot Blasting, generic term like all vacs are Hoovers, and although a different media and applicator is used, Grit, sand, bead and vapour fall into the same classification. Initially coarser grade were used to strip and clean the metal surfaces, but then a “Sealing” operation using metal or glass beads closed the surface the former had cut open.
Another problem not appreciated is the cross contamination by using “Used” blasting media. Stainless Steel and Alumininininium “Rust” quite well if you’ve done a bit of mild steel first.
I think the aircraft industry picked up on the walnut shells as that was the developed method for removing the crud from airfield marker light glass covers in situ rather than strip and scrub.
Not going to have a go at anodising Ramon??
Regards Ian.
Missed the bit about “Grit”, Grits and sand have sharp corners wheras glass beads are exactly that and impart a “Peening” opeation.
Edited By Circlip on 21/02/2010 12:05:47
Edited By Circlip on 21/02/2010 12:06:16
Edited By Circlip on 21/02/2010 12:08:35
