Backplate fitting
Backplate fitting
Home Forums Beginners questions Backplate fitting
  • #10545
    Anders Be
      @andersbe
      Anders Be
        @andersbe
        Dear all!
        Working with a lathe, cortini H105 (swing 105 mm). The chuck is mounted with a 1-1/2"-8 tpi thread. The chuck is 125 mm in diameter and say 80 mm long including back plate.
        If I push the chuck (or a bar mounted in the chuck) forth and back introducing a rather low bending moment on the chuck, the radial movment at the outer end of the chuck is say 0.02 to 0.03 mm. However as close as possible to the bearings I don't see any movment. I suspect this depends on movmens in the thread fixing the backplate to the spindle.
        Could I be right?
        If yes, is this what I can expect from a mounting with thread and a stright register?
        If not, what can the problem be?
        Bad axial fiting? Could be, but I have verify it with mark color.
        Fiting of the register? Spindle is 37.97 and backplate 38.00 mm in diameter giving a gap of 0.03 mm.
        Bad fitting in the thread? The fitting is not tight so to say.
        I combination of all?
        Any other suggestion or thaught? Bearing problems anyway?
        Thank you for your reading.
        Best regards
        Anders B
        #508618
        Ady1
          @ady1
          As long as the thread can tighten up properly, it's fine
          The key part is the SPINDLE REGISTER
          If the thread is too tight it may even interfere with the proper fitting on the register, so a bit too loose is better
          2cents
          Its the nice smooth bit behind the thread and it has to be very accurate
          Edited By Ady1 on 19/11/2020 23:20:13
          #508622
          Anders Be
            @andersbe
            Many thanks for your answer. What would be the ideal diameter of the register in relation to spindle diameter?
            Best regards
            Anders B
            #508624
            Ady1
              @ady1
              Your machine has specifications for that number, a few pictures of your setup and the parts involved would make it easier to explain/help, and we could see what your register/bearing setup looks like
              That picture btw comes from a useful post in here
              Lathe Spindle/Chuck Concentricity
              Technique Required to Make Accurate Backplate
              Edited By Ady1 on 19/11/2020 23:32:37
              #508705
              Howard Lewis
                @howardlewis46836
                If the chuck can be moved, it is not seating properly.
                Either the backplate on the register, or the chuck on the backplate. And, are the fixings tight with all surfaces clean, and free from dirt or damage.
                Off course, it could be that jaws are a poor fit in the chuck body?
                I would suggest starting checks with the register / backplate, then backplate / chuck body, until you find the cause.
                #508771
                old mart
                  @oldmart
                  Smart & Brown use a 1 3/4" X 8 thread with a 1 3/4" register. We have about 8 chucks and faceplates with clearance between the spindle register and the bore of the backplate from 0.0005" (0.0125mm), to 0.020"(0.508mm). They all tighten up and repeat perfectly for concentricity and face flatness. The important thing is that the rear face of the plate is in tight contact with the corresponding face on the spindle. The most difficult chuck to attach to the lathe spindle is the one with the tightest fit.
                  #508794
                  Tony Pratt 1
                    @tonypratt1
                    Posted by old mart on 20/11/2020 17:26:18:
                    OK I will be the first to ask, with .020" clearance on diameter how do they repeat on concentricity ?
                    Tony
                    #508815
                    old mart
                      @oldmart
                      It has to be the threads centring each time, there is no other explanation. I would usually check a backplate on its own when the chuck is off being cleaned, and have never had to correct any runouts. The only threaded spindles that totally rely on that register are Raglan, I believe they use square threads. I have had to remachine the square end of backplates and that is when the front face would need a skim.
                      #508835
                      Anders Be
                        @andersbe
                        Many thank!  Ady1. Have only briefly glanced through the first thread, the measured gap is much smaller, say 0,004 mm rather than 0,04 that I have. Have to read them carefully …
                        Best regards
                        Anders
                        Edited By Anders Be on 20/11/2020 22:34:52
                        #508989
                        old mart
                          @oldmart
                          How would you measure a gap of 0.004mm, my feeler gauges only go to 0.001" which is 0.025mm.
