Back on topic:
Summary:
– New digital issues, and some back issues (>= #278) use an HTML5 reader, and so are not affected by the Flash End-Of-Life
– Majority of the back issues (<= #277), are not accessible anymore, unless one goes to some trouble to re-enable Flash.
How to re-enable Flash:
Here's what I found so far.
Adobe announced the end of Flash in 2017. It is likely that the "time bomb" (Adobe will block Flash content from running in Flash Player beginning January 12, 2021) was inserted into the Flash Player already at that time. One solution would be to install a pre-2017 Flash Player – full of known unpatched security holes. Not the best.
There's an official proper way to continue to use Flash for specific things. In the Flash Player Administration Guide there is a section "Enterprise Enablement". It explains how to add particular locations to a whitelist of allowed URLs. After this is done, Any allowed Flash content will continue to run on browsers that have not disabled Flash Player (even after January 12, 2021).
Proposed solutions to the magazine:
– Prepare an easy-to-follow, step-by-step guide with a lot of screenshots, so that anyone could set this up. Could be as simple as a downloadable ready-to-use mms.cfg and instructions where to copy-paste the file, depending on OS.
– Make older back issues available as PDF downloads. Let this be available for subscribers only, or if you're feeling generous, for everyone. If somehow you don't have the archive in PDF, I can tell you where to get them
– Consider providing new digital issues in PDF as well. Like I've discovered, it's already trivial (for a subscriber) to download the new issues (in jpg or pdf, individual pages – one file per page). These download links are not even password protected, so once any subscriber shares a link somewhere, anyone without a subscription can download them. Would be more convenient if there was a proper single-file download option, this should be password-protected (require a valid subscription)
