Hi all,
I posted something about this yesterday and it was a tooth missing from my back gear cluster which sits at the bottom of the headstock.
do I need to worry about a tooth missing even though it still seems to work fine when I use back gear, which is not very often, and if I were to replace the back gear cluster how would I go about it.
has anyone ever done it before, if so, could you give a few pointers.
im reluctant to do the job seeing as it’s working ok, but it may need doing sometime.
also does anyone else use their lathe ok with broken teeth.
the lathes a Myford ml7.
thanks
Chris m
