Back at last !
Back at last !
  • #78490
    magpie
      @magpie
      Hi Folks
      About 12 months ago, my computer went caput, and i had to get my son to install a new motherboard. Having done this he installed Windows 7. This is when my problems started. I found that i could not post on this site. I would type in a post, click on “add post” and it would just vanish !
      I sent an email to Diane to ask what i was doing wrong, and the answer was that the site could not deal with a 64 bit system ( Whatever that is ?). Anyway i have just found out about Firefox and i can now post on here again. So if anyone else out there is as dozy as me, and cannot post using Windows7, you now know why
      Cheers Derek
      magpie
        @magpie
        #78494
        Steambuff
          @steambuff
          I am using 64 bit Windows 7 and IE9 (Also 64 Bit) with no problem.
          Diane is Half right.
          You have to set the page/site to “Compatabilty Mode” to post — Its the icon at the top that looks like a torn sheet of paper. (Click it – It will go blue)
          Then post away.
          Anonymous
            Funny, I did a quick post on this site this afternoon from work using Windows 7 and IE version something or other. I didn’t click on any ‘Compatability Mode’ stuff. It worked fine?
            #78503
            Steambuff
              @steambuff
              I have only seen the issue with the 64 bit version of Win 7 and a 64 bit version of IE … The 32 bit versions seem to be OK.
              Les Jones 1
                @lesjones1
                Hi Derek,
                First test
                This is just a test to see if I can post using internet explorer 9 on my windows 7 64 bit system. I have been posting on this forum using this system with Firefox with no problems.
                Second test
                The first test failed. This test is now with compatability mode turned on.
                Les.
                #78509
                magpie
                  @magpie
                  Whoo Hoo cheers Dave it works. ( well it does if this appears).
                  Derek
                  #78529
                  alan frost
                    @alanfrost17805
                    If what appears?
                    #78533
                    magpie
                      @magpie
                      Hi Alan The post.
                      Cheers Derek
