BA fastener washer dimensions
Home Forums General Questions BA fastener washer dimensions
  • #21993
    Anthony Knights
      @anthonyknights16741
      Anthony Knights
        Just received some mail order 10BA washers which look too big to me.
        They have an OD of 4.3mm with a 1.9mm hole. I have trawled the internet and found numerous sites which give thead dimensions, but cannot find spec. for washers. Does anyone know the correct dimensions. Alternatively, where can I get this information without paying BSI a small fortune.
        Thanks in advance
        Tony
        #81944
        The Merry Miller
          @themerrymiller
          Anthony,
          B.A. washers are supplied as Large or Small.
          The outside dia. of 10 BA large is 0.171/0.176″
          Hole dia. is .073/0.078″
          Thickness is 27swg (0.0164″)
          The reference book I’m looking at now only goes down to 8BA for the small washers.
          The above abstract was from BS 57 and it’s obvious what you have are large 10 BA washers.
          Len P.
          #81946
          The Merry Miller
            @themerrymiller
            Just discovered the full BS 51 spec for your edification Anthony.
            Len. P.
            #81947
            The Merry Miller
              @themerrymiller
              Posted by The Merry Miller on 13/01/2012 13:08:38:
              Anthony,
              Len P.
              Should be BS 51.
              Len.
              #81969
              Anthony Knights
                Thankyou Len. dimensions more or less match the washers I have although they still don’t look right when used on my model horizontal engine.
                Tony
                #81989
                Sub Mandrel
                  @submandrel
                  Hi Anthony,
                  Very few full size engines have washers under their nuts.
                  Anthony Knights
                    Washers would stop me damaging the paint job.
                    Tony
                    #82190
                    Anthony Knights
                      The link I was given for the BA data no longer seems to work. Have I been blocked from accessing this data by some mysterious webmaster?
                      #82197
                        Anthony can you get away with brass washers, I noticed yesterday that my 10BA brass ones were quite a bit smaller than the steel ones I have. As far as I know both wer bought from EKP.
                        Link still works for me.
                        J
                        #82256
                        Anthony Knights
                          Link works for me again today, so I,ve printed the whole lot in case I lose it again.
