Posted by John Haine on 04/07/2022 07:40:18:
Chatter? What grade is the brass?
Most brasses machine well but not all. There are dozens of variants. I have a length of DIY store brass rod which is unusually hard and prone to chatter; it saws, files and polishes OK, otherwise difficult stuff. Their Aluminium is soft and sticky and their steel gritty too.
My DIY store Brass looks identical to the Brass rod bought from my local metal emporium, but his Brass machines with zero bother.
DIY store metal is easy to source, but expensive and liable to be uncooperative on a lathe or mill. It's sold for decorative purposes, not metalwork. For the same reason I avoid unknown scrap. I'm happy to try it, but after painful experience able to recognise when it's the material causing trouble.
Difficult metals often can be machined, but they're unforgiving, requiring the operator get the tool, rpm, depth-of-cut and feed-rate close to optimum.
The Brass is a likely suspect if the lathe cuts other materials satisfactorily. However, I'd expect hex rod to be a machineable alloy, lube not required, so:
- use sharp tool with minimum overhang. Tool and don't wind the cross-slide out too far
- as hex rod starts with an interrupted cut, check the cutter with a loupe: it may be damaged
- keep length protruding from chuck short, or support with a live centre in the tailstock
- check chuck (worn jaws, loose jaw, dirt or distorted hex rod allowing rocking)
- loose bearings or gibs.
- saddle dipping due to bed wear
- hard spot in a belt
- bent shaft on the motor or elsewhere
- motor running rough
- if, to avoid off-cut waste, a long length of rod is passed through the headstock, make sure the far end can't whip.
I see from other posts the lathe is a Portass PD5, so at least 50 years old. Check for wear, tear and other age related problems. A 0.33HP motor is probably a little undersized for a machine of that size, but adequate – I doubt that's the issue.
Edited By SillyOldDuffer on 04/07/2022 10:28:03
