I just saw the lathe this evening. I'm not sure if I've mentioned it before, but this is the first time I've seen a lathe in reality.
I think that I spent an hour but I have the feeling that there were a lot of details that I missed or I was completely unaware of. And I have even more questions now … but here are my remarks so far:
– I put a 6mm mill in the chuck and I measured the concentricity error at 10mm from the jaws. The maximum deviation was 0.1mm (0.0039"
– I fixed a comparator on the compound and put the tip on the bed. Then I set a low speed for the carriage and move it across the whole length. Maximum error was 0.04mm (0.00157"
– I tried to lift the carriage using moderate force and the comparator didn't moved a micron.
– We cut my steel rod from above. First with a 0.1mm cut. The surface was very smooth. Then we cut 1mm deep using a carbide tool. There was a sharp strong noise a lot of smoke from burned oil. It was not something that I would like to replicate. The bar was almost to hot to touch after. The surface also looks nice. Now I realized that I should use a much longer bar. Actually the seller had one prepared but I didn't realized it's purpose. The highest difference in diameter for the 1mm cut is 0.01mm(0.00039"
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
– I opened the gear box. There was clean oil at the bottom and the edge of the wheels feels sharp. There was no suspicious noise in any gear setting. Both longitudinal and transversal automatic feed is working
– all the slides run smooth and apparently there is no backslash.
– In order to change the speed sometimes you have to manually rotate the chuck. But I suppose this is normal, the wheels are not always aligned.
– The tailstock can be adjusted only horizontally
I think I will return to cut a half a meter bar. I used this comparator.
How do you think are the measurements so far?
If I cut a long bar what is the maximum expected error for a lathe in good condition?
Edited By Sonic Escape on 13/02/2023 19:48:12
Edited By Sonic Escape on 13/02/2023 19:50:55
Edited By Sonic Escape on 13/02/2023 19:55:23
