Aveling and Porter 2 ins compound steam roller
Home Forums Model Engineer. Aveling and Porter 2 ins compound steam roller
  • #270247
    Michael Williams 14
      @michaelwilliams14
      Gentlemen, I am well into the building of the above roller using the drawings in the magazine published in the 70's. However, the cylinder drawings are rather small for such a complicated assembly. Does anyone know where any drawings might be obtained for this roller please?
      Kindest regards to all,
      Michael Williams, Cheshire.
      I have my own patterns for the front rollers and forks if anyone is interested. Castings were done for me in cast steel in Stoke.
      Michael Williams 14
        @michaelwilliams14
        Help wanted with cylinder drawings
        #270289
          Myhobbystore do them as do Blackgates.
          Welcome to the forum too.
          J
          #270351
          Michael Williams 14
            @michaelwilliams14
            Many thanks for the prompt reply. I look forward to being involved with the forum.
            Best regards, Michael Williams.
            #270362
            Scrumpy
              @scrumpy
              Hi Michael some months ago I had a bleed behind the eye which ment I had problems with parts on some drawings of my 2 in Showmans engine I went to a local copy shop and had parts blown up this they told did not infringe copywrite as it was only parts , So interesting you are building a roller as this could be my next build regards Derek
              #270366
              Michael Williams 14
                @michaelwilliams14
                Hello Derek, thank you, a good idea as I do not need a full set of drawings…..Blackgate want £47 for the set. I can send you some pictures of the parts I have made when you are ready. I believe it will be quite handsome when finished.
                #270387
                Harry Wilkes
                  @harrywilkes58467
                  Hi Micheal
                  What I've done in the past is take a pic of drawing for (quick view) with phone you can then zoom the image or long term take pictures with digital camera then load it on pc , then in my case I use paint shop pro to enlarge the photo and then print or just take certain parts of the photo enlarge and print those !
                  Cheers H
                  PS Is this the John Haining APRIL Roller if so I may still have digitised copies on a cd that's if I haven't thrown it out as I no longer have my 2''
                  #270389
                  Scrumpy
                    @scrumpy
                    Hi All I thought about using my iPad or iPhone but as I passed the copy shop each day I had the parts that I wanted blown up X 6 so no problem seeing the small details ,As for my next model I think it will be a 2 in roller my brother is building a 3 in marshal but this is to big for me , rollers seem to be the neglected part in the model world Derek
                    #270393
                    Michael Williams 14
                      @michaelwilliams14
                      Dear Harry,
                      Thank you for your comments. The roller in question is the 'M.E' Aveling and Porter 2 ins, which featured in volume 140 of the magazine in the mid 70's. I have all the magazine covering the complete build of the roller but as explained above, the detail of complicated parts like the cylinder block are difficult to interpret! The design is by John Haining.
                      Michael
                      #271429
                      Michael Williams 14
                        @michaelwilliams14
                        This matter is getting more interesting by the day. I spoke with our group in the last few days and the general comment was that the cylinder design was poor…..as the low pressure available from the copper boiler would make the HP/LP approach inadequate on power, being say 80psi.. As an alternative it was suggested that two HP cylinders would be better, say of 1inch diameter. The cylinders would be constructed with removable liners so that enlargement would be possible if the engine was under powered. I am told that Haining published articles in the ME around 1977 of a Ransomes 2 inch tractor which had 2 HP 1 inch cylinders. Has anyone any comment to make about this please?
                        So with this in mind a look at the alternative drawings is my next goal as i am minded to accept the points raised above.
                        #271433
                          You could build it to drawing and fit a simpling valve then just run with that open all the time which would give HP steam to both valve chests so allowing it to be run as a double high.
                          Or alter the boiler design to allow for higher working pressure though you probably won't get much more than 120psi
                          Edited By JasonB on 12/12/2016 20:56:47
                          #273397
                          Michael Williams 14
                            @michaelwilliams14
                            Thank you for your idea….it would make the design closer to the original. I need to do some power calculations. The boiler is copper, so whilst a higher pressure would be helpful, probly best left as is!
                            Kindest regards,
                            Michael
                          Home Forums Model Engineer. Topics
