Hi Les,
Thanks for the reply, you are right with what I want to do, it is fairly simple really but I am not really sure which way to go so I was looking for suggestions and thought perhaps someone had already done something similar.
The guillotine has a fairly good scale but I can see mistakes creeping in due to the amount of repetive moves needed.
After some googling I thought ELS was probably not suitable but found a post on a forum asking the same question about a guillotine backstop, added a post and received the following reply
The ELS can even do it now although there’s no distinct home switch to automate things. On power up you’d have to move the fence to the zero position and zero the scale. After that you can key in a BEGIN position and press START. With the X axis disabled, the ELS will always stop and ask you to move the tool into the workpiece. At that point you’d shear what you wanted. Press the BEGIN button again and enter a new position, press OK. Press TURN and START and the fence moves to the next position. It’s kludgy but it would work.
Thanks for the link for the Divisionmaster, I see they also sell kits for the ELS which are slightly cheaper and was also hoping to keep it simple as possible.
Peter
