I make my own PCBs.
There are lost of ways of doing this, and I’ve tried several – dalo pens, rub-down transfers, laser-printer toiner transfer. I’ve even done a double sided board using a dalo pen in a pen plotter… all these methods can work, but they are crummy. The one route to success is to use boards with UV-resist.
The best way of making positives for UV-resist board I have found is laser printing (Samsung SCX-4200, Scotch laser film). The film, costs 1/3 the cost of the printer, but lasts ages.
Don’t buy a light box, get some of the ‘deep purple’ disco-light tubes (I believe they call them clubs these days) and build them into a box. Calibrate your box and stick to he tiings that work best for you.
Keep unused boards in the dark and cool. They last 2years+ in a cupboard in my workshop.
Eagle PCB design software is free from their site, limited to PCB size and two layersarea limitation is only on part placement -so lay your tracks around the edges to get quite bit of extra area! Steep (very) learning curve, but once you have designed and eagle board and procesed it using UV resist you won’t want to go back.
To do double sided, use two sheets of film separated by a bit of spare board, and expose one side at a time.
After some trial and error, I find I get MUCH better results developing UV resist with NaOH solution, than with the ‘modern’ solutions. But I use about 15g of NaOH pellets per litre, which is half the ‘old fashioned’ recommendation. Keep the solution cool.
On the other hand, warm up the ferric chloride in the microwave (carefully) to get it to etch faster and more evenly.
Use meths to remove the etch resisit, or a kitchen ‘scratchy’ or wet and dry. Don’t use your garriflex blocks, it seems to ruin them.
Believe it or not I use my 5-speed pillar drill with the standard ‘micro-box’ type HSS drill bits with great success. Just adjust as miuch slop out of the spindle as you can. Don’t try carbide bits at such low speeds.
If you do break a drill, I found (in desperation) that if you run it at high speed and gently stoke one of thoss cheap diamond slips across the end it eventaully gets a sort of tip on it that WILL drill FR4 epoxy board with very little extra pressure. Indeed the resulting ‘stub drill’ has much less tendency to wander.
I always use a bit of plywood as a backing when drilling PCBs.
If, like me, your PCBs end up as bodged as your drills, you will need to add holes, possibly at a point when the PCB has components on both sides. Again necessity being the mother of invention I discovered that expanded polystyrene is an ideal backing material, as you can push the components into the board so it is supported and flat while drilling.
I have successfuly made boards for surface mount parts with 0.5mm pin spacing. soldering these was… interesting.For all SMT ICs I have a slightly unconventional approach. I tin all the pads very lightly, removing solder if there is too much and testing with a multimeter to make sure there are no shorts. Place the chip and using a very lightly tinned iron with a pointed tip press the pins at two opposite corners down onto their pads. Check alignment now, while it is still easy to release the chip. If it is on straight, just proceed along the edges of the chip, pressing the legs down onto their pads. You’ll find you can feel the slight give as each leg drops and allow just a half-second for the leg to fuse with the solder on the pad. Very different from using a hot air gun or an oven, but ‘it works for me’ – except when I do my favourite trick of forgetting to do all the pins on one side of a four-sided chip.
