Hello All;
I have my new ZAY7045FG/1 Milling machine now in my shop and set up. The tramming of the Z axis was a challenge due to the weight of this brute but now have it set right on.
A couple of questions to others with a similar machine, how do you lock a R8 collet into the spindle and not have it turn. I thought that the machine would have a brake type of lock similar to the Bridgeport’s but it does not.
The next question is how to make the machine work in a counter clockwise direction. Yes, for drilling and tapping one can select this feature and set up the depth and it will drill and or tap to a depth then reverse itself out of the hole. But I cannot find how to get it to milling in a counter clockwise direction. Why you might ask, well left hand mills.
There is supposed to be a way to set up the clutch which is used for selecting the various speeds when doing powered drilling or tapping. The manual does not cover procedure so I am hoping someone might be able to assist.
Thank you in advance.
