Raymond,
I do not want to go into this problem too deeply. Reactive chemicals like Alum (Potassium Aluminium Sulphate), Ferric Chloride are intrinsically chemically reactive. They would all rather be some other compound with a higher energy barrier and so be more stable.
To do the tap removal trick: –
1. Degrease the tap and hole. This is important!
2. Build a little dam around the hole using wax/modelling clay/shellac/PCB resist. Do not let any go down the hole.
3. Use an eye dropper/pasture pipette or W.H.Y. drip in your reagent.
4. Make sure you do not get air trapped in the hole.
5. Let the reaction start. Wash out and refresh as needed.
Do not use acids they will not work well in this way.
Selotape (Durex for those who live upside down where the Cross hangs in the sky) I have never used it. (U.K. stuff has semi-water soluble glue).
The last time I had to pull this stunt was in 1996 on a 12 BA tap (or there about) I used some candle wax (from a real ‘Frankie Randall’ not one of those smelly things the S.W.A.M.B.O’ have in the bathroom). I like good old Carbolic anf a lump of bath brick -to get rid of any clinkers- my self
For small taps It works! And is cheaper than building a ‘Sparky’.
Good luck
Dick
Edited By Richard Parsons on 21/08/2010 12:55:08
