First, to reiterate some previous comments, the use of the word Luddite in the context of the original post is incorrect, and shows woeful historical knowledge.
Being idle I tend to use whatever technique is quickest, whether that be by hand, manual machining or automated. But then again I'm interested in the destination, not the journey. Machining is simply a means of producing a part, it is not a destination.
The skills needed over time change. For instance take marking out. I rarely mark out now, with a DRO on the mill it's simply not needed, and less accurate. The only exceptions are for hand formed sheetmetal work and some starter points on castings, if required. Some "skills" were just darn hard work, so for me it's no great loss if they die out.
The question of CNC raises it's head with monotonous regularity. In order to get the best from CNC milling a wide skillset is needed. For starters one really needs to be competent with 3D CAD. In addition a good understanding of speeds 'n' feeds and cutting tool performance is needed. Judging from comments on this forum many people simply don't understand this, even on manual machines. One also needs to show forethought and some skill in designing fixtures for work holding so as to not impede the cutter. While CNC is not the answer to everything it allows one to design and make parts that would be time consuming, difficult, or impossible, on manual machines. It also relieves the tedium of making multiple parts. Whether manual machining experience is needed before moving to CNC is a debate that has been raging on the professional forums for many years. I think the consensus now is that it is not needed. Remember that in the professional world the person doing the CNC fixtures and programming is not usually the same person operating the machine. The machine operator is lower skilled and hence cheaper.
While some people bemoan the loss of tradtional skills, I wonder how many of them are prepared to pay for such skills? Wasn't there a company making lathes using traditional manual machining and hand fitting skills? I wonder what happened to them?
I suspect that the disconnect between modelling and professional machining is probably getting wider. When I was looking for ideas on capstan tooling I came across several relevant articles in Model Engineer, in the 1940s I think. Can you imagine the same now?
That's enough pot stirring, I've got an aircraft to inspect and then I'm afternoon tug pilot, although at the moment even the ducks are walking, unless they're instrument rated.
