Posted by John MC on 12/04/2020 13:00:56:
I considered buying one of these. First impression was that its a triumph of styling over design, not a good starting point! Having said that reports at that time suggested it did a good job on the ends of the cutter. But what about the sides of the cutter? This machine only does half a job. I was hoping it would replace my Clarkson T&C grinder but, as I mentioned, it doesn't do the complete job.
I've stuck with the Clarkson, its a real pain to use, probably because I have a sharpening session once or twice a year and need to re-learn the machine each time.
I think you've said it all there John.
Because it includes all the jigs and guides it does one thing well – grinding the ends of end mills, quickly and simply enough that no theoretical knowledge and only modertate practical ability is needed.
The Clarkson on the other hand can do much more, at the expense of requiring skill and patience.
Whether it suits really depends on how you wear your end mills; many of us put most of the wear on the tips and for those it's ideal – except you do need to sharpen a few dozen end mills to make your money back.
