Hi All,
I have just received the set of carbide slip blocks/gauge blocks that I won on eBay recently and very happy I am too – solid carbide so no issues of rusting and bought them for the proverbial song.
However the box and the blocks themselves are covered in a thin layer of what is best described as 'gunge', I suspect that the box has been left open in a workshop environment (they are grade 1 under BS4311 so I believe they are workshop, not calibration quality) and I suspect that its just a layer of general condensed coolant and the like, however I want then clean.
So…I guess I could find a large container of something in the brake cleaner/degreaser department and dip them through that but I also contemplated running them (separately) through the ultrasonic cleaner. Maybe starting with a dose of WD40 and then wipe the excess off along with the gunge might work too?
I am concious that I should not be doing anything to the slip faces themselves other than the bare minimum.
I am sure that there should be an expert (or two) on this matter and I look forward to your advice (hopefully not conflicting!)
Simon
