Outside doors in every room? (Sorry, being flippant). I recently helped someone with drawings for a two story extension for an older house. The building regs are quite clear on escape routes in the event of fire, opening windows are a large part of this. I believe new regs have just been introduced.
Kitchen: exits in to two different hallways at each end each with external doors.
Living Room: tri-fold doors to outside
Master Bedroom: french windows to outside
Guest Rooms x 2: exit directly into main hallway with external door.
Fire Safety Approved Document B including amendments up to 2022
2.1 See Diagram 2.1a. All habitable rooms (excluding kitchens) should have either of the following.
a. An opening directly onto a hall leading to a final exit.
b. An emergency escape window or door, as described in paragraph 2.10.
