Having made one with no problems with an ML10, I offer the following:-
The spacing rods, ensure you allow a small clearance so the table will move back and forth easily.
Do NOT paint the sides of the frame where the table slides back and forth.
After painting allow some extra time for paint to dry and harden unless stove enamelled.
Make sure your lathe will take the length of rods so that you can work at the extreme ends ( You may need a Fixed steady)
Make sure you have all the taps and dies for the threads on the Worden.
You need to cut a 40 TPI thread for the thimble micrometer spindle.
Definately buy the Diamond wheel conversion kit. (Essential for carbide tools)
check what milling cutters you have (Metric and Imp.) and buy enough metal to make the different holders.
The table angle indicator is a bit of a conundrum for fitting and making, decide what you will do before you start making the machine.
The finish of the worktable surface, I did this with an orbital sandiing machine as it gives a nice surface.
Do NOT lubricate anything on the machine, it will pick up dust and bind.
I did blacken all the working bits with a commercial blackening kit. ( About £35 all in) There was just enough fluid in the kit to do it if you dont overload the surface area in the fluid. One piece at a time is OK.
The lack of hieght of the wheel is a problem,as the table rises against the hieght of the wheel as the angle increases. I would have thought by now it would have been addressed by Hemingway? (Perhaps look at Jim Whetrens method of raising and lowering the motor)
I have a couple of photos in my photo gallery of my Worden.
