I bought a new Myford from the old Myford if you see what I mean, about 10 or 12 years back. It has served me well though I have converted it to CNC, but in retrospect I would not buy another one.
First I think the whole design shows its age and is over engineered. Too many components, not enough design. That's why they are so expensive.
The drive system should have been updated years ago. Modern high power 3 phase motor and vfd should be standard in a lathe at this price. The lathe vibrates horribly on the high speed ranges.
Why have a two ball bearings at the back of the spindle that still need regular oiling and a plain taper sleeve bearing at the front that needs oiling every day rather than good quality taper roller bearings? The bed design is basically poor, should be the prismatic type used on every other modern quality lathe. And it isn't as rigid as it should be if I recall some comments from the late great Sir John.
Topslide is flimsy, I've now eliminated it completely. Power cross feed is prone to jamming (as the Myford sales manager effectively acknowledged when I asked him at a show). And the price differential for pxf is silly, ought to used the same components with a dc motor. In fact it shouldn't be an option but standard.
Documentation is appalling for an expensive product bought in the 21st century. The standard manual doesn't actually describe the lathe you buy, fails to point out that the leadscrew on the "metric" lathe is actually 1/8" pitch, the MT4 spindle is non standard. The MT4 to MT2 adapters they supplied don't actually run very true.
So whilst I have no intention of changing my lathe, having invested hours and hours in the cnc conversion and calibration, if I was starting again I'd probably buy a high end Sieg machine and spend the difference on other tooling.
