Hello
I thought I would share this technique. I am wondering if it is a standard way of working.
Simply put, if my pen is really too fat for the job in hand, I draw a long thin L shape and work from the 'far' edge of the L.
e.g. In this photo I am trying to measure exactly 10mm. To mark it I have drawn a rather fat blue line with my 0.5mm Frixion pen (which has the advantage of be erasable cleanly, without any rubbings). The red dotted line is the line I will need to cut the (white) material which I am marking.
NOTE: "For good measure", in this case I have used a steel block to butt up against the white material, so that I can use my engineering rules (i.e. rulers which have no lead-in and start at zero), to make 100% sure that my measurement is starting precisely at the edge of the white material.
Discussion
It seems to me that the only down-side of drawing from the edge of an "L", (rather than from the centre of a short line – that is hopefully drawn with a thinner line), is that it's a bit more time consuming to remember which side of any given marking one is supposed to be working from!
Also when marking out more complex shapes it quickly becomes confused if one is working on the EDGE of a line rather than the CENTRE of a line.
Which is why I started this thread:
"Need a pen to draw the 'finest possible' lines?"
https://www.model-engineer.co.uk/forums/postings.asp?th=179283
So when you folks are needing to work with great precision:
– Do you folks tend to draw Ls or short lines?
– What other tips & techniques can you share that help with your accuracy?
Cheers
Don
Edited By Donald MacDonald 1 on 19/04/2022 13:36:23
