No. 3 on head weight. Rig up a strap before tilting. I took the one on my Chester version over to about 20° shortly after installation and it almost escaped. Took a fair bit of grunting, groaning and impressive verbals to get it back. Naturally I dropped the spanner for the locking bolts too. In those days I was quite happy to lift a hundredweight or more from floor to bench or more.
I went the other way to KMP and moved up to a Bridgeport. In the home shop, where drowning in coolant or being buried in swarf spoils the fun, maximum metal removal rate and safe cutter size comes out pretty much the same. The really big difference is when setting up work. The combination of big square head, small table and spindle coverage limited to a little over half the table Y-axis width makes life much harder from both visibility and elbow room considerations. For obvious physical reasons these, along with machine stiffness, are inescapable compromises for any machine seriously smaller than a Bridgeport. You need to take a very careful look at the compromises of particular layouts before buying, table size isn’t everything, visibility on the aforementioned 626 type being far better. I went round many laps before deciding on the square column one!
From the picture it seems the Warco still has the abominable screw up and down spindle depth setting stop. Those things take geological time to set and are more than a little springy. I stuck a plain rod in mine, drilled out the threads in the nut and welded a wing nut head onto a screw to lock it in position. The little plate with an arrow went for a gremlin toy, eyeing up the scale with the bottom of the nut was just as good. Set in seconds and far more rigid. I had a 3 axis DRO with the Z on the quill so this little mod made repeating depth settings a breeze.
I often considered that a depth stop on the column would be really useful too but never got round to doing one. On reflection a multi position one like the 6 rod bed stop I have on my lathe or the 4 screw one on my router sounds like it could be very good on the right jobs.
Mine was unusual in that it had a two speed belt drive and inverter controlled three phase motor to give around 40 to 2800 rpm in two ranges with decent overlap in the middle. In my view best of breed layout. At the time the price / performance / specification ratio didn’t work but were the idea revisited now prices could be competitive.
Inspection followed by strip, clean and re-lube is probably a good idea with any inexpensive machinery. It certainly seems that a single set of parts is provided which must be assembled into a machine regardless so some horrors do get through. The spindle and gearbox are driven at higher speeds so a listening test should be good enough. I always feel that mixing oils isn’t ideal so cleaning out that supplied and replacing with your favourite seems good. Also give you a chance to set-up things to run just so and verify that the tape gib adjusting slots fit snugly on the adjuster heads. Excess play here can drive you nuts as the table self adjusts its gibs during operation! Mine lacked pushes on the table locks so the plain bolt ends chomped into the gib where they touched.
Edited By Clive Foster on 18/11/2011 23:54:55
