Posted by John Smith 47 on 23/03/2021 13:41:47:
Thanks for all your quick responses
[Note I have now added a PS to my post of 12:36 today]
Regarding accuracy of the 45 chamfer, I need to make a bit load of them at least 32 of them and they ALL need to be able to meet and create a 90° join.
The reason for the accuracy is thatt they are for magnetic guides and even a 0.1mm gap will cause a significant drop in magnetic pull.
I'm not sure what 'magnetic guides' are but if you want the magnetic force to hold these parts together at right angles and you are concerned about a 0.1mm potential gap you might need to use guage plate or have the steel parts hardened.
Since these items have more or less a cutting edge (like a plane blade) they will be very subseptible to damage or burrs so even if it was a perfect 45 degree bevel it might not remain so for very long.
Since you mentioned this was an idea for a 'product' it might be sensible to have a batch made by an engineering company or an individual rather than buying machinery and learning how to use it. As others have said the most appropriate DIY method is that suggested earlier by Andy Stopford .
Are you hoping that the magnetic force will hold two parts together at a right angle just by the contact along the bevelled edge?
Ian P
