Any advice for fitting Rockettrinics ELS to Super7
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Any advice for fitting Rockettrinics ELS to Super7
Viewing 21 posts - 1 through 21 (of 21 total)
  • #653138
    jaCK Hobson
      @jackhobson50760
      I have an old S7 with MachineDRO DRO fitted. I fancy making up for lack of gearbox and power cross feed by fitting an ELS.
      I prefer easy projects to challenges. So I'm thinking I get as much from Rockettronics as possible.
      Any advice on benefits of the pro controller over basic?
      I think I get the kit for lathes upto 150kg (3nm) but get the servo version (I guess less issues with missed steps)? Or should I go for a larger kit (more torque at 8nm).
      Thanks for any advice
      jaCK Hobson
        @jackhobson50760
        Electronic Lead Screw (ELS)
        #653141
        John Haine
          @johnhaine32865
          I have no views on the supplier. But, if you are motorising both leadscrew and Xfeed then in my view you might as well go for full CNC.
          On my S7n I have 2 standard NEMA23 steppers, the main leadscrew being driven with a 2:1 toothed belt reduction, and I think 2A drive current. I have never had an issue with missed steps except when I've managed to crash a tool (but that seldom). For a Myford I can't see that high torque or servos will be much benefit.
          #653155
          John Hinkley
            @johnhinkley26699
            Jack,
            Have you seen the note on the Rocketronics web site that states that the els kit is currently metric only?
            When I fitted an els to my lathe, I used bits available from James Clough and followed his method of control using a nema23 stepper motor with error feedback inbuilt. Pictures in my album. This only gave control on the Z-axis as I didn't have powered crossfeed.
            William Chitham
              @williamchitham75949
              This fellow Jan Sverre Haugjord on Youtube has done a number of ELS installs on various Myfords: https://youtu.be/vzGhr4lxajY
              Not the slickest presentation style but lots of info if you have the patience to dig through his videos.
              William.
              #653214
              jaCK Hobson
                @jackhobson50760
                Thanks All.
                Jan has a much better presentation style than me, And a much cleaner S7. I think he uses the servo kit and the cheaper controller.
                I think the more expensive controller can display rotational indexing positions so could replace the dividing head (well, need a spindle lock) which, if I could be bothered to sell, would pay for the extra. But, when did I last use the lathe for indexing?
                On the lathe, I only work in metric now I have DRO (although I am just beginning to realise that imperial seems more convenient for woodwork). I think you can just config a conversion ratio in the controller so it isn't a problem adapting to the imperial leadscrew.
                I suspect the MDRO install is going to complicate the cross slide feed which is a shame.
                I am a bodger (actually, that is an insult to real bodgers). I make stuff without planning or drawing. The automation on the Rockettronics would aid this approach. CNC needs some planning. I want things to be simple to 'pick back up'. I got really into 3d printing with heavily modified printer and firmware, and quite good at Fusion 360, but after a break I can't face the learning curve to work out how it all works again… so I don't want to make that mistake again. Maybe I do CNC on the mill next.
                Edited By jaCK Hobson on 22/07/2023 09:54:32
                #653224
                jaCK Hobson
                  @jackhobson50760
                  The pro controller has lots of advantages. I like the rotary input knob for jogging
                  https://www.youtube.com/watch?v=Ju1xzv6tQVE
                  #654060
                  jaCK Hobson
                    @jackhobson50760
                    So I ordered. Price showed incl Vat, but I didn't actually get charged VAT. Now it stuck awaiting customs payment… and I'm awaiting payment instructions via snail mail. Take back control!
                    #657740
                    Matt Harrington
                      @mattharrington87221
                      Jack, I have a Rocketronics system on my S7 and I am enjoying getting to grips with it (not much spare time during the summer months) .
                      Albeit only metric, a simple division by 25.4 will create the imperial threads you want.
                      My only gripe is that the entry level unit is slightly different to the PRO version (which I have). The PRO version does not have the auto pause facility when threading if you only motorise the Z axis. It was initially a pain as I wanted to thread before I motorised the X axis.
                      I'm happy to post pictures etc for my installation.
                      I initially implemented the Atomic ELS system but wanted to fully automate threading – the Atomic ELS only supports Z axis implementation.
                      Matt
                      #657748
                      jaCK Hobson
                        @jackhobson50760
                        Nice. I got the Pro.
                        I forgot I started this thread so added to an old one:
                        I'm currently installing on an old Super 7. It is a cheap way of getting the equivalent of power cross feed and gearbox (gearbox alone now goes for the cost of the complete kit).
                        I could easily pull it all off if I switched machines.
                        The challenge with the install is how to physically connect the components : spindle encoder, x and Z motors.
                        Some observations:
                        I have the 'hidden under the cross slide' DRO from machine DRO and this would complicate putting the Z motor on the back of the cross slide (where it would probably look nicest. So I'm putting mind on the front, using a bracket bolted to cross slide T-slot.
                        The toothed belts/wheels for printers (and 3D printers) are cheap and good for light loads. '2GT' 2mm pitch 6mm wide. Lots of options next day delivery on Amazon. Excellent for spindle encoder… but I didn't find them until I had already used 5mm pitch 10mm wide. I will see if it is enough for cross slide…. an 80 tooth wheel replaces the dial gauge while retaining the handle which is really neat. 60 tooth might work and be even neater.
                        Certainly happy to stick with bigger belts for leadscrew. I put it on the handwheel end.
                        Document from rocketronics suggests not to gear down steppers too much (steppers lose torque at higher revs so gear down for torque doesn't always help) and stick to whole ratios.
                        Now I just have to wire it all up…
                        #658269
                        jaCK Hobson
                          @jackhobson50760
                          So I made a few wiring and dip-switch mistakes but I got all the motors working… now have to calibrate.
                          #658868
                          jaCK Hobson
                            @jackhobson50760
                            Easy conical threading!
                            'embed' option gone from Youtube for me
                            But after this I restarted and the screen stays blank and will not play anymore. Just as I was starting to have fun
                            It doesn't seem like a common problem so I have to wait for Rocketronics support – they have been on holiday
                            Edited By jaCK Hobson on 02/09/2023 18:03:38
                            #658870
                            jaCK Hobson
                              @jackhobson50760
                              I note it seems to do all sorts of things… except ball handles. Elliptical grooves and tapers, so you can have half a ball but not a ball handle…
                              Std screwthread relief to DIN 76-1 seems a nice feature.
                              #683456
                              Dell
                                @dell
                                I have Rocketronics on my Myford ML10 and love it best upgrade I have done even sold the change gears as I don’t use them any more, the worst part for me was the electronics, also added 3 phase & vfd so no belt changing either.
                                Dell
                                #689753
                                jaCK Hobson
                                  @jackhobson50760
                                  I’m finally back in action. Rocketronics support is fantastic but…
                                  I returned my unit as we could not determine why it wasn’t working. It took almost this long to arrive back at Rocketronics due to the German courier and customs losing it for a while..
                                  Rocketronics sent me out a brand new one after waiting a month… It has taken over a month to arrive… AND I had to pay import duty all over again – another £100. It was in UK customs for 3 weeks. Supposedly I might be able to claim it back. NOT Rocketronics fault… Brexit.
                                  Rocketronics could not find fault with the device I returned?! My guess is I have a dodgy power supply… it is working OK at the moment though.
                                  It is a fantastic bit of kit! Rocketrinics are great – you can trust them! However, Brexit rubbish, not fit for purpose, not as advertised, and I want a refund plus compensation for my trouble!
                                  #689937
                                  Tony Pratt 1
                                    @tonypratt1
                                    Don’t blame Brexit for the customs cock up!
                                    Tony
                                    #689942
                                    Roy Vaughn
                                      @royvaughn26060
                                      Why not blame Brexit, that’s why customs are involved now.
                                      Roy
                                      #689943
                                      jaCK Hobson
                                        @jackhobson50760
                                        I absolutely do blame Brexit! Dealing with EU suppliers was simples in the past. Right now, it is easier to buy from China than EU.
                                        #725719
                                        jaCK Hobson
                                          @jackhobson50760
                                          My new retirement plan is to become a youtube influencer with quality video content
                                          https://youtube.com/shorts/0uVSNC0zVuk?si=sMjKRpnPdp0M1mmn
                                          #725724
                                            The mind boggles !
                                            Bazyle
                                              @bazyle
                                              There is some paperwork you do before sending back an item for repair – even before Brexit. Used to do it at work years ago and got a ref number for customs but can’t think what it is called now,
