Another problem
Another problem
Home Forums Electronics in the Workshop Another problem
  • #613781
    Haydn Callow
      @haydncallow19480
      Hi, I’ve bought a 5 pin stop/start switch ….I think I should have got a 4 pin one.
      I’ve wired the 5 pin in the cable between the wall plug and the drum switch…easy enough but when I press the green start button the lathe springs to life but when I release the green button the lathe stops. I think the green button should stay down until I press the red stop button. The small 5th pin is not in use.
      Can I somehow use the 5 pin switch ? Or do I need a 4 pin ?
      thanks in advance.
      Haydn Callow
        @haydncallow19480
        5 pin stop start switch
        #613784
        Dave Halford
          @davehalford22513
          A lot of the cheap start/stop switches are like doorbell push switches and designed to operate a relay, you need a latching type. The number of pins is irrelevant.
          #613786
          Robert Atkinson 2
            @robertatkinson2
            can you provide a link to the switch you bought please? Otherwise we are just guessing which helps no one.
            That said you probably just need to add a link on the back of the switch.
            Robert G8RPi.
            Edited By Robert Atkinson 2 on 16/09/2022 14:48:49
            #613795
            Haydn Callow
              @haydncallow19480
              Hi, yes sussed it and all good now….had 13 and 23 input. 14 and 24 out…..then a 5th pin A……just connected A to 24 and all good
              Thanks
              #613901
              Anthony Knights
                @anthonyknights16741
                "A" is obviously the feed to the solenoid, which operates and holds the contacts closed, now you have connected it to the outgoing supply.
