I have now learned there is a difference between machining EN1A & EN3B steel!
I want a 1.5mm wide slot, 6mm long 3mm deep in the end of a 12mm bar with a 6mm hole through. It's to insert a key to make a D hole so that the flat on an electric motor shaft will drive the rod. Eventually it will be a dog clutch.
Made the piece from a very short length of EN1A steel I had lying about. Very pleased, made the slot first attempt with no trouble.
Then I messed up the other end, and had to start again. The only 12mm I had was EN3B.
Three (admittedly cheap) 1.5mm carbide milling cutters later I had the new slot. The first broke (my fault) because I took too big a cut (1mm depth), The second grabbed where the slot breaks through into the central bore. The third just broke!!
EN3B does not machine as well as EN1A, at least at my skill level!! Now I know that.
