Posted by brian jones 11 on 25/06/2021 23:48:54:
You mean the typical old MEM Motor starter. This has a built in thermal trip on prolonged overload. Early ones didnt have a no volt trip feature and should be changed out as the motor could start up again after a trip = dangerous.
You no doubt refer to the MEM Startlet which was not a DOL starter as it had no coil fitted, it was only a mechanical switch with a current related adjustable overload feature that tripped the switch OFF.
That was not what I was referring to in my earlier comment as explained above.
DOL starters were the next stage of progress with motor control and are still used widely in industry, not all motor installations benefit from soft start or speed control as given by other types of control.
Emgee
