Hi again,
I now have some results – not great – but at least something to report.
First off though I’d just like to say thanks to all of you who have responded so far, your input is much appreciated.
I finally cobbled together the neccessary items to have a go at this process and have jury rigged a set up using a 20 volt power supply that was made years ago to drive the cross slide milling spindle motor. Control was via a Variac on the input side and a test meter ut in circuit to measure the current. A spot of ‘alchemy’ provided dyes – two greens from Dylon cold water dyes and two from disolving whole tubes of artists water colour into about 300mls each.
The tank was filled with acid that was mixed several years ago as a pickle though never used. It appears very ‘clean’. Having thought about it I’m sure I mixed this with clean rain water.
The cathode is a lead strip about 75mm wide and runs down the side, across the bottom and half way up the other side.
The hanging wires are from 1.5 mm ally welding wires bent back on itself and pushed a tight fit into a hole drilled into the test pieces (these were parted off from the stock the cylinder heads were made from – probably HE30 though not certain.
The first test piece was cleaned in cellulose thinner dried off then washed in the cold (room temperature) washing soda degreaser. 20 mins or so produce a rather striated effect which I put down to poor degreasing. It did however have a different ‘feel’ to it rubbing it across some wet and dry on a flat surface. It would not however take any colur. After ringing someone I knew who had some experience with anodising I was told to make sure the soda degreaser was hot and to increase the current and time to about 40 – 60 mins. His experiences weren’t very encouraging regarding the colouring however as he had had a similar lack of take up. What he had been able to get to take albeit poor colour though had been acheived by an increase in amperage.
The second piece was left in for 50 mins and the current increased. This resulted in a much better part – a smooth and uniform nice grey finish. Dissappointment then to find despite an hour in the dye not so much as a speck of colour anywhere. I mixed up the violet dye as I have read that greens can be difficult but no luck there either.
These are the second (left) after treatment and the third part before
I decide then to do as Bernie had suggested and use a 12volt battery to get a much higher current. Left in the same amount of time this did not come out any near as evenly coated as the second and as you can see left a deep pitted hole near the hanging wire.
Despite the much higher current this did not take up any dye either.
The second part will not pass a current across the surface. The third will in areas – passing the test probe over the surface leads to intermittent connection.
My thoughts so far are that the current needs to be increased lightly more than the first set up can give. The time could be slightly longer perhaps. The biggest area for improvement has to be the connection between the hanging wires and the parts as I think that the area of contact is too small and probably reduces throughout the process.
I’ve bitten the bullet and ordered a decent supply unit which is something that’s been needed for some time but always got by without.
I’m perplexed by the lack of dye take up at this time but quite impressed by the surface finish on the second piece. I will try inks next and wonder if solvent based dyes would work too
If anyone has any furth <
