Angle of Clack Valves
Home Forums Locomotives Angle of Clack Valves
  • #588779
    Jon Lawes
      @jonlawes51698
      I'm looking to incorporate top feeds in a boiler but don't want the spindly top feeds you often seen on the tops of 3.5" Britannias and such; they look great but I don't think my machining is quite of the required standard. As a result I figured a standard clack into a threaded bush (as per many backhead clacks) would be my best bet, albeit up higher on the side of the boiler.
      How much angle from the vertical do we think a clack will tolerate before needing the assistance of a spring to close? Is it worth making them with a small spring anyway just to improve their efficiency?
      I know some of this has been covered before but not this specific question, sorry to those who may have seen it all before.
      Jon Lawes
        @jonlawes51698
        #588793
        Former Member
          @formermember12892
          #588799
          Jon Lawes
            @jonlawes51698
            Thank you Bill, I am a member over there, I shall try there shortly and compare the notes from here.
            #588811
            duncan webster 1
              @duncanwebster1
              You can make the one on top of the boiler a dummy (ie just an elbow) and put the real clack further down the pipe hidden under the running boards
              #588820
              Jon Lawes
                @jonlawes51698
                A good point well made
              Home Forums Locomotives Topics
