anadale 210v-g lathe
  • #41203
    gordon brian davies
      @gordonbriandavies53132
      varible speed
      gordon brian davies
        hi, there everyone im new to this hobby which i enjoy experimenting trying to
        make things on my lathe, i have a anadale 210-g varible speed lathe,the varible
        speed does not run at constant speed when set, any one come akros the same
        problem? im down in carmarthenshire thanks
        #577460
        Andy_G
          @andy_g
          Hi, Do you mean an Amadeal 210V lathe?
          https://www.amadeal.co.uk/acatalog/AMAT210V.html
          Is the problem that the speed varies as you start to cut, or does it just run erratically, even with no load?
          If the latter, I would look first for sticking or worn brushes in the motor, and if there wasn't a problem there, it could be a worn control potentiometer (they're not good quality and do fail).
          #577475
          Pete Cordell
            @petecordell95786
            I would give the potentiometer speed controler a clean with some switch cleaner
