Hi Ady1,
While I thank you for your response and I concur with your observation, I feel it is not the whole picture.
The water bottle if observed from above would have the window at twelve o'clock. Thus the side nearest the window should be the coolest. The vapour always tends to form at two to three o'clock. Which coincides with the position of the Sun's rays coming through the window.
The down wash from the window flowing over the edge of the sill onto the counter top. Rather like the Dry Ice special effects mist used on stage performances, flowing off the stage into the audience.
Would I feel tend to make the vapour form nearer the base of the bottle and all the way around the base of the bottle.
This does not happen, the vapour always forms a near perfect vertical band up the entire length of the water bottle. The height of the bottle has no effect, as a taller version of the bottle exhibits the same vertical vapour band.
Placing the water bottle in the window on the cold tiled window sill, yields the same result.
Gray,
Hi Jeff,
I think your views are on the right track and you may well be right. I was of the opinion that the Sun's rays were being reflected around the curvature of the bottle internally. Thus heating the sides and rear of the bottle more than the side nearest the Sun. Which due to it's shiny surface would tend to reflect some sunlight.
As an aside, and a further observation. On the mornings when the Sun is not out, and the Bread Maker is in use and sits next to the sink. The water bottles still exhibit the same vertical vapour pattern and at about the same two o'clock position. The Bread Maker being at the nine o'clock position.
Which would tend to blow my theory out of the water.
Gray,
Edited By Graham Meek on 18/11/2022 11:12:55
