An interesting device, on ebay
Home Forums Workshop Tools and Tooling An interesting device, on ebay
  • #548443
      It has some battle-scars and is, I presume, inaccurately described … but this looks like it has potential : **LINK**
      https://www.ebay.co.uk/itm/393278763448
      Does anyone recognise it ?
        peak4
          @peak4
          Never seen one before, but I wonder if it's a tap tapering/sharpening attachment for a tool and cutter grinder.
          Bill
          #548484
          AdrianR
            @adrianr18614
            The scars on the nose seem to be at regular angles, I wonder if the threaded bit is a gland for hydraulics to increment a rotation. The angles look to be preset at 30, 45 and 60 degrees, could it be for sharpening/making countersinks?
            #548490
            Circlip
              @circlip
              Strange how so many bits of metal clag are classed as "Lathe – Myford" and anything with a flywheel advertised as "Stuart Turner". At least now, not all turning tools are suitable for Myford .
              Regards Ian.
              #548496
              Cornish Jack
                @cornishjack
                Similar thoughts to Peak 4.
                Same sort of set-up as the tool-holder in the Boremasters Tiplap – but surface mounted rather than on a round shaft. The 'trough'. which. I assume, would hold the tool, seems to be limited to one width only.
                rgds
                Bill
                #548522
                ega
                  @ega
                  Posted by Circlip on 06/06/2021 08:58:18:
                  Regards Ian.
                  And how many advertisers profess to know nothing about their offerings!
                  #548599
                  old mart
                    @oldmart
                    Three posts in a row reflecting exactly what I was thinking. laugh
                    #548609
                    John Paton 1
                      @johnpaton1
                      This looks very similar to the work holder on a small valve refacing machine I once owned.
                      At one time any decent garage had one as valve grinding was a standard requirement at 50k miles ( and valve lapping at pretty much every service!)
                      I still have the diamond fixture used to true the grinding wheel and only hung on to this in the hope that one day someone will say they need one.
                      #548613
                      John Reese
                        @johnreese12848
                        I think John Paton nailed it.
