New Scientist 21 Sept p 51 shows a simple model intended for youngsters to make to explain equinoxes etc. It goes on to explain precession of the earths axis, saying that this wobble goes round in 25,772 years. The picture shows the precession circle about 3 earth diameters north, and rather less than the equator diameter. BUT it goes on – 'in around 13,000 years time, summer in the northern hemisphere will happen when it currently experiences winter'.
I suggest that there are two things wrong with this statement-
1. the change over the next 13,000 years depends on where the precession angle is now. If it is half way to max lean, the effect of precession in 13,000 years will be back where is started from, for instance.
2. If the description and diagram of precession is correct, what will happen is that the seasons will slowly become slightly more (and less) distinct as we go through the 25,000 year cycle.
Surely if the seasons do wander in a 25,000 year cycle because of precession, then the term precession (of whatever varies) must involve a greater angle than the about 5 degrees shown? And it is not a simple wobble but a rotating one? And if so, why have I seen no references to a series of seasonless periods in recent geological time?
Many thanks for any clarity you can offer.
Regards, Tim
Edited By Tim Stevens on 22/09/2019 15:17:32
