An alternative to parting-off
Home Forums Hints And Tips for model engineers An alternative to parting-off
Viewing 7 posts - 51 through 57 (of 57 total)
  • #379728
    fishy-steve
      @fishy-steve
      Posted by Bill Pudney on 08/11/2018 01:45:24:
      Some time ago I got an optical centre finder, it was on sale at the time. It has many useful functions, two of which are centre finding (that's a surprise!) and tool height setting, simply stick it in the tailstock chuck, and you can see the tool in scary detail. To my mind better than all the gauges, tools etc.
      cheers
      Bill
      Hi Bill,
      What sort of accuracy can be achieved with the optical centre finder? I've never used one.
      Thinking on it a bit your method would only work on my Boxford if I allowed for the fact that my tailstock is sitting a couple of thou low due to wear on the base. I must get around to shimming it up.
      Steve.
      ega
        @ega
        Posted by Oldiron on 04/11/2018 12:54:43:
        Here is an interesting webpage for those interested.
        Thanks, Oldiron, for these tips from the horse's mouth; it is indeed interesting to compare them with opinions on the thread (always remembering that the author is concerned with industrial applications).
        #379763
        larry phelan 1
          @larryphelan1
          From the number of Posts generated by the above subject,it seems I was right when I said that many of us have problems parting off [OK,some dont,as we know ].
          Front post,back post,door post ,goalpost,you name it,above center,below center,even off center !
          It seems that what works for one is dead meat for another,and as for setting the tool height to a thou ????,wishful thinking for most of us,who can just about see the tool,never mind the tip !
          It has been very enlightening reading the different views and one does learn something from them and helps to point out where one might be going wrong. We,at the bottom of the heap,will just have to try a bit harder,since we have a long way to go,if some of the claims are to be believed.
          PS The vision of a lump of 10" round whizzing around is SCARY to say the least ! not that I doubt it has been done.
          Did someone else part off 18" in the good old days ? Brave men !cheekycrying
          #379879
          Andy Pugh
            @andypugh44463
            I hadn't realised that this thread had prompted such discussion. (I don't seem to get notifications)
            Anyway, as it turns out I am 100% serious about this, and I used the attachment this very evening to finish the cut through some 4" Meehanite bar.
            I am sure that it is possible to part much bigger stuff but it does get proportionately more difficult as the tool extension gets greater. I have done some big stuff, but it only takes a moment of inattention or for one of the metal nautiluses to get wedged and you are looking around for another parting tool blade.
            My current parting-off tool is an insert-type which takes 2mm tips, but it isn't the blade type, it is one of the more solid ones from P H Horn. **LINK** It does a lovely job, but only goes so deep. I machined a blank Multifix block from Create Tool to match the T-shaped interface.
            As for the suggestion of taking the work to the saw rather than the inverse: The three-jaw chuck makes a much better job of holding short round stock than the bandsaw base does.
            #379886
            Bill Pudney
              @billpudney37759
              Hi Bill,
              Steve.
              Hi Steve,
              In absolute terms I don't know, however the magnification is sufficient to make tiny changes to tool height to be VERY obvious. So, having used it (Opt Ctr Finder) more than 10 years, I'm very comfortable with setting it just below the horizontal line visible in the viewfinder, so I'm guessing that it's 0.015 to 0.02mm below. Tool height setting is now a very consistent process. After setting it's very gratifying to find that the tool parts off very cleanly, with no noticeable centre pip….except on cast iron, of course, which is a law unto itself!!
              Mine is a Chinese one which was on sale at ENCO in the US, it certainly wasn't what I'd call cheap but it was priced way below what I've seen European retailing for. It's not often that you see multi use bits of kit!!
              cheers
              Bill
              #379959
              John Haine
                @johnhaine32865
                Regarding tool height setting. When I was working out how to calibrate tools and store offsets on my CNC lathe conversion I realised that making sure every tool was at the centre height was important. For example if you turn a piece with a tool and you are turning to a different diameter to the one at which the offsets were calibrated, an error is introduced if the tool is not at centre height and you turn to a different diameter assuming the offsets are correct. In particular if for example you set the tool to a 6 mm gauge, when you try to accurately turn to a larger diameter without stopping, measuring and taking a bit more off, you find you've turned off too much. I now set tool height using a digital height gauge which at least resolves to 0.001" and try to set to that accuracy for each tool. It takes a lot longer but I have more confidence in getting consistent results.
                #379963
                Andy Pugh
                  @andypugh44463
                  For centre-height settting, these are pretty and make good christmas presents:
                  https://www.machine-dro.co.uk/edge-technology-speedy-lathe-gauge.html
                  Edited By Andy Pugh on 09/11/2018 14:57:39
