Posted by ega on 07/11/2018 13:52:59:
If I read you correctly, you would recommend that the rear mounted carbide tool be set below centre?
Can you elaborate on "cope badly"?
Yes, if the tool were rear mounted, it'd want to be physically below centre.
If the work rides over the cutting edge of the insert as the tool gets to the centre of the job, due to flexibility in either work or tool holding, then it puts the cutting edge of the tool in tension rather than compression. It just peels the front off the tool before you can do anything about it.
If the cutting edge is fractionally above centre, it's harder for this to happen and the insert will happily push through the last little bit of stock so long as it's in compression.
Having the tool below centre will cost you an insert per cut
Edited By Mark Rand on 07/11/2018 15:46:35
