I built a model boat hull about twenty years ago – wooden keel and formers with aluminium sheet glued directly to the wood using Evostik. The aluminium was simply abraded clean with emery clean. It is about 36" long, powered by a 5cc Diesel engine. It is still in useable condition despite years of water (fresh and salt), diesel, various oils, vibration and numerous collisions. Due to a design oversite, the hole for the propellor shaft had to be drilled after construction, which effectively cut the keel in two at the point the shaft tube went into the hull. The brass prop-tube was then also glued in place with Evostik, and has never shown signs of leaking or breaking free. I never expected the thing to survive as well as it has, so I guess that is as good a recommendation as any. I can't tell you the type number of the Evostik I used, but it was just a tine of the stuff bought from a local hardware shop, probably just aimed at general use.
I have tried on occasions using Araldite, and found it to be a complete waste of time – it eventually goes brittle, and breaks away from the aluminium, however the surface is prepared. Similar effects occurred with fibreglass type resins.
Two-part glues labelled 'polyurethane' seem to be better, but I have no long term experience of them.
