ammeter shunt
ammeter shunt
Home Forums Electronics in the Workshop ammeter shunt
  • #756012
    duncan webster 1
      @duncanwebster1
      I’m thinking of putting one of these on my little battery loco. I can get either a 50A or a 10A shunt. The MCB is rated at 50A. Presumably the 100A has lower resistance, and I’m not looking for super accuracy, so that looks like the better bet?
      Robert Atkinson 2
        @robertatkinson2
        Both the shunts drop the same voltage at full current, 0.075 V This is not a lot in a 12 or 24 V system but the 100A will drop 0.0375 at your MCB rating of 50A . The description says the resolution is 0.1A for both so no advantage there.
        Apart from lower voltage drop the 100A one will let you see if the current is higher than the MCB rating.
        I’d get the 100A out of those two
        If cost was no object I’d use a Hall effect sensor as they don’t drop any voltage (I have some in stock).
        #756176
        duncan webster 1
          @duncanwebster1
          Thanks, but your Hall effect thing got me interested. Something like HSTS016L? 2.5 V output which is easy to read, and around £11 from ebay
          #756181
          Phil Barber
            @philbarber30745
            Note these need to go in the negative line.  I got one but was not suitable for my application.
            Let us know how you get on with Hall’s effect.
            #756216
            Robert Atkinson 2
              @robertatkinson2
              I’ve not tried that type but they should work fine.
              Robert.
              #756218
                You’ve caught my interest now, Robert & Duncan
                … This looks a useful intro.
                https://solarduino.com/how-to-measure-dc-and-ac-current-using-hsts016l-hall-effect-current-transformer/
