Amazing EDM machined Japanese stamp
Home Forums The Tea Room Amazing EDM machined Japanese stamp
  • #778687
    Morse Homology
      @morsehomology91685
      The stamp is so precisely made, you can retract the complex stamp design to a mirror face. Couldn’t upload an animated gif, but the action is shown in this link.
      【MIRAIN】custom made seal, signature stamp Made in Japan
      (or for just the action in the animated gif; here)
      Longer video showing the process.
      Back in the day we hired a contractor to EDM machine some cartwheel flexures into a block of martensitic steel; wish we had heard of these guys, as they obviously did a better job (the flexures were not parallel).
      Plasma
        @plasma
        Wow, that’s precision cutting.
        How does the wire cut then? It’s obviously some kind of sacrificial process I’m guessing.
        Is the stamp for some commercial use, like an inspection stamp on a certificate?  They looked to be making more than 1 of that particular design?
        Mick.
        #778702
        Tony Pratt 1
          @tonypratt1
          Basically a brass wire is the sacrificial cutting tool fed from one spool through various tensioning rollers and current pickups onto another spool after it has passed through the work area, normally .2mm in diameter but you can go down to .1mm if memory serves but the .1 did tend to snap on a regular basis.
          Tony
